Old 12-19-2008, 11:47 AM   #11 (permalink)
Mom's Taxi - '05 Toyota Sienna LE 8-passenger
90 day: 22.59 mpg (US)
Diesel - '09 VW Jetta TDI
I've been searching for a lower 6th gear for my '06 Corolla XRS to no avail. Anyone know where I might find one to fit the Toyota C64 6-speed tranny?
(Same basic tranny used in the Celica GTS, Matrix/Vibe GTS, as well as US Lotus Elise, Exige)
Thanks in advance!
Old 12-19-2008, 11:50 AM   #12 (permalink)
There is nothing readily available as far as I know. It would have to be custom.
Old 12-19-2008, 12:15 PM   #13 (permalink)
Custom 6th gear? Who? Where? How much? Any links?
Thanks in advance.
Old 12-19-2008, 12:24 PM   #14 (permalink)
Funny's Avatar
Eco-Fit - '13 Honda Fit Base
90 day: 37.06 mpg (US)
C64
3.166 2.050 1.481 1.166 0.916 0.815
I am pretty sure that the 6th gear (and all others) in:
C60
3.166 2.050 1.481 1.166 0.916 0.725
are able to fit up.
Hope that helps.
You may want to find a C60 transmission in a junkyard
Wikipedia quote:
6 Speed transaxles
C60
Above 300+whp 3rd gear and Final Drive will break. Gear ratios for this transmission.
1st 2nd 3rd 4th 5th 6th Reverse Final
3.166 2.050 1.481 1.166 0.916 0.725 3.250 4.529
Applications:
2000-2005 Toyota Celica
Toyota Corolla
2003-2006 Toyota Matrix XRS
2003-2006 Pontiac Vibe GT
C63
3.166 1.904 1.310 1.031 0.864 0.725
[edit] C64
1st 2nd 3rd 4th 5th 6th Final
3.166 2.050 1.481 1.166 0.916 0.815 4.529
Applications:
2000-2005 Toyota Celica with the 2ZZ-GE engine
Toyota Corolla Sportivo (Australia)
Toyota Corolla TS (Europe)
Toyota Corolla Compressor (Europe)
2005-2006 Toyota Corolla XRS (USA)
Toyota Corolla Fielder Z Aero Tourer (Japan)
Toyota Corolla Runx Z Aero Tourer (Japan)
2004-2007 Lotus Elise (North America/UK) (mid engine application)
2005-2007 Lotus Exige (US/UK) (mid engine application)
American by right
Ecomodder by choice
Hypermiler by necessity
Old 12-19-2008, 12:36 PM   #15 (permalink)
Funny's Avatar
You probably want to try to find the transmission for the 2002 Celica with the 180Hp engine (GTS) whereas you have the transmission found in the 140HP(GT) version. Check out the specs on this webpage
Jeez, I feel like I'm doing all the footwork...
American by right
Ecomodder by choice
Old 12-19-2008, 12:57 PM   #16 (permalink)
Thanks for attempting to help...
You are correct, the '06 Corolla XRS (which is what I drive) has the exact same Yamaha-designed 2zz-ge engine and the exact same C60 6-speed tranny as the Celica GTS.
I've researched the "easy" swaps ad nauseum. If the Celica/Matrix/Vibe 180 bhp GTS models had had more favorable gearing- I would have swapped for one of those long ago.
So it looks like I need a custom 6th gear? I need something taller than the 0.725 6th gear that comes stock in my C60 tranny.
Again: Who? Where? How much?
Thanks in advance.
Old 12-19-2008, 01:04 PM   #17 (permalink)
Do a search here for 5th gear swap. There was a nice thread on someone who did it on a ZX2.
Old 12-20-2008, 09:04 AM   #18 (permalink)
Funny's Avatar
C64
Applications:
Your transmission has the 0.815 6th gear I believe, you may wish to attempt to find the C60 transmission that I suggested to get the 0.725 6th I am talking about.
If you are dead set on getting a custom sixth gear, try and get into contact with Doug Heffron, creator of the XFi "Areo Car". He made a taller fifth gear for his metro to get 75mpg on the highway. Check out this article for more details.
Hope that clarifies that even further.
Edit: Here is the quote from metrompg.com:
MetroMPG.com: The newspaper article mentions changes to the transmission - can you explain that in a bit more detail?
Doug Heffron: The transmission was the hardest part. 1 found a way to change the 5th gear ratio. I made the gears myself on my lathe. A very proud moment for me. The local machine shops wanted $2,500.00 for 2 gears.
American by right
Ecomodder by choice
Old 12-20-2008, 04:22 PM   #19 (permalink)
@ Funny-
Wikipedia confused me as well. My 2006 US Corolla XRS came with the C60 with a 0.725 6th gear. I looked it up online to be sure. I also re-verified with both my tachometer and scan gauge on the highway:
60mph:~2700 +/- rpm
70mph:~3150 +/- rpm
If my car had the C64 tranny- the 0.815 6th gear would yield
60mph:~3045 rpm
70mph:~3553 rpm
Since my rpms are no where near that high, I must conclude that either my tach and scangauge are way off and I have a C64 tranny- or Wikipedia is incorrect and I have a C60 tranny. Which is it? Thoughts?
If I do have a C60 tranny, then I suppose my only option is to go with a custom 6th gear in the <0.659 range.
Thanks in advance.
Old 12-20-2008, 06:07 PM   #20 (permalink)
Ezcape - '15 Ford Escape Titanium
90 day: 20.22 mpg (US)
There is a gearbox which will work for your Corrolla and you can have ANY ratio you want in ANY gear 5 or 6 speed and all gears have interchangable ratios, and straight cut so they even use less power. There you are, all you need to do is buy the gearbox.
"The Stone Age did not come to an end because we had a lack of stones, and the oil age will not come to an end because we have a lack of oil" ; His Excellency Sheikh Ahmed Zaki Yamani (Saudi Arabia Oil Minister from 1962 to 1986)
https://ecomodder.com/forum/em-fuel-...ehicleid=10608
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 44 12-08-2014 11:22 PM
Saturn S-Series 5th Gear Swap cfg83 EcoModding Central 61 05-02-2012 09:31 PM
Taller top gear makes a real difference (10%) Multiades EcoModding Central 58 04-21-2010 09:06 PM
Review: 2009 Toyota Corolla LE (37.9 MPG) RH77 General Efficiency Discussion 22 05-09-2008 04:55 PM
Win an EM Sticker: guess Dad's mileage (Toyota Corolla automatic). Ends Jan 13. MetroMPG Hypermiling / EcoDriver's Ed 51 02-07-2008 09:02 AM
