Old 02-03-2008, 12:25 AM   #14 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Originally Posted by bennelson View Post
Mostly I am asking because of the possibility of converting a Miata.
Mostly I'd say: do it!
You're perhaps going to suffer some more energy losses. The biggest challenge is going to be fitting the batteries due to the car's small size (you might have to consider 8v or 12v batts to get the pack voltage you want without overloading the car).
Traction won't be an issue with the battery weight on board. If you're planning to use it in snow, you'll need winter tires all around though.
The fun you'll have with a Miata EV will far outweigh the drawbacks.
