Everybody should remember that you need some water flow at all times the engine is running, to keep from having hot spots around the heads. (Can you say "warped heads" and "head gasket leaks"?) Even with the thermostat closed there is water circulating through the heater core, which is good in the winter for your body and the engine both!
