Old 12-22-2008, 12:17 AM   #13 (permalink)
guudasitgets
Fokus - '12 Ford Focus SE
90 day: 33.73 mpg (US)
Lecksus - '03 Lexus RX300
90 day: 17.61 mpg (US)
Benzzzzz - '11 Mercedes Benz ML-350 4-Matic
90 day: 22.83 mpg (US)
Ezcape - '15 Ford Escape Titanium
90 day: 20.11 mpg (US)
Funny, youd have to build the engine to just burn Methanol, the fuel you can find, go look at some dirt tack sites and youl find places to buy it. But the engines have to run higher compression, longer duration cams and more advance timeing to start with. Materials won't matter much, your bigger concern is engine mods to run the stuff. And if you never been next to a car running it, all I will tell you, it's enough to make a growen man cry. Also helps to run a magneto and not electronic ignition. This is the one time your better off throwing out the electrnic spark box and just run a straight mag. It's sorta hard to ignite, almost to the point like I said before you need to start it on gasoline.
"The Stone Age did not come to an end because we had a lack of stones, and the oil age will not come to an end because we have a lack of oil" ; His Excellency Sheikh Ahmed Zaki Yamani (Saudi Arabia Oil Minister from 1962 to 1986)
https://ecomodder.com/forum/em-fuel-...ehicleid=10608
