I was thinking the same thing, but on a smaller scale. Hot spots around the combustion chamber along with a slightly lean mixture might result in aluminum heads getting soft and the seats loosening up, but the gage never reporting and overheat condition.
+1
else we'd have electric water pumps ....
mimicking the thermal curve for all temperatures is difficult, I like the solidity of a water pump and simple thermostat that opens rheostically. the thermostat electric is as smart as it gets...in fact I go seek one. Even the older classic thermostat is still a champ.
and furthermore, there is still failures, inlines will always be a gasket exploding host spot imbalanced retarded culprit...woops I rambled a bit....
