12-22-2008, 05:45 PM
Pokémoderator
Hello -
The 183 MPH sounds like a salt-flats speed record. What was the actual cost of production of the EV-1?
Here's something that will make you throw up :
General Motors EV1 - Wikipedia, the free encyclopedia
EV1 CNG
The compressed natural gas (CNG) variant was the only non-electric vehicle in the line-up, even though it employed the same up-stretched platform. It used a modified Suzuki 1.0-liter turbocharged 3-cylinder all-aluminum OHC engine installed under the hood. Due to the high octane rating of the CNG (allowing for a greater compression ratio), this small engine was able to deliver 72 hp at 5500 rpm.
The batteries were replaced with two CNG tanks capable of maximum operating pressure of 3000 psi. The tanks could be refueled from a single nozzle in only 4 minutes. In-tank solenoids shut off the fuel during refueling and engine idle, and a pressure relief device safeguarded against excessive temperature and pressure. With the help of a continuously variable transmission, the car accelerated 0 to 60 mph (96.6 km/h) in 11 seconds. The maximum range was 350 to 400 miles, and fuel economy was 60 mpg (in gasoline equivalent) .
EV1 series hybrid
The series hybrid prototype had a gas turbine engine APU placed in the trunk. A single-stage, single-shaft, recuperated gas turbine unit with a high-speed permanent-magnet AC generator was provided by Williams International; it weighed 220 lb (99.8 kg), measured 20 inches (50.8 cm) in diameter by 22 inches (55.9 cm) long and was running between 100,000 and 140,000 rpm. The turbine could run on a number of high-octane alternative fuels, from octane-boosted gasoline to compressed natural gas. The APU started automatically when the battery charge dropped below 40% and delivered 40 kW of electrical power, enough to achieve speeds up to 80 mph (128.8 km/h) and to return the car's 44 NiMH cells to a 50% charge level.
A fuel tank capacity of 6.5 gallons (24.6 l) and fuel economy of 60 to 100 mpg (3.9 to 2.4 L/100 km) in hybrid mode, depending on the driving conditions, allowed for a highway range of more than 390 miles (627.6 km). The car accelerated to 0-60 mph (96.6 km/h) in 9 seconds.
There was also a research program that powered the series hybrid Gen2 version from Stirling engine based generator. The program demonstrated the technical feasibility of such drivetrain, but concluded that commercial viability was out of reach at that time.
EV1 parallel hybrid
The parallel hybrid variant featured a de-stroked 1.3 L turbocharged DTI diesel engine (Isuzu Circle L), delivering 75 hp, installed in the trunk along with an additional 6.5 hp DC motor/generator; the two motors drove the rear wheels through an electronically controlled transaxle. When combined with the AC induction motor which powered the front wheels, all three power units delivered a total output of 219 hp, accelerating the car to 0-60 mph (96.6 km/h) in 7 seconds. A single tank of diesel fuel could keep the car running for 550 miles with a fuel economy of 80 mpg.
A similar technology is used in the 2005 Opel Astra Diesel Hybrid concept.
A bird in the hand ...
CarloSW2
