ATayloracing We did that in road racing, ground off two of the for blades off the impeller, then they came out with underdrive tooth belt pulleys
Intrigued; Why are belt drive pumps a problem? Simplist thing on earth and they never slip and you can get all sorts of ratios in pulleys for them. Look at the Cosworth 4 cylinder BDA in the pic, click on it and you will see the small belt drive I'm refering to.
"The Stone Age did not come to an end because we had a lack of stones, and the oil age will not come to an end because we have a lack of oil" ; His Excellency Sheikh Ahmed Zaki Yamani (Saudi Arabia Oil Minister from 1962 to 1986)
https://ecomodder.com/forum/em-fuel-...ehicleid=10608
