Old 12-24-2008, 01:27 PM   #54 (permalink)
Intrigued
Losing the MISinformation
Intrigued's Avatar
Quad Cam - '00 Oldsmobile Intrigue GX
Last 3: 25.94 mpg (US)
Lightbulb Learn something every day!
Originally Posted by guudasitgets View Post
Intrigued; Why are belt drive pumps a problem? Simplist thing on earth and they never slip and you can get all sorts of ratios in pulleys for them. Look at the Cosworth 4 cylinder BDA in the pic, click on it and you will see the small belt drive I'm refering to.
Wow. You learn something every day! I just haven't had the opportunity to delve into timing belt/chain stuff, other than replacement. Since I didn't get into the racing side, except for some occasional drag racing, I didn't know there were different pulley sizes for timing belt-related stuff, and so on. Underdrive v and micro-v crank pulleys and so forth, yeah, but then all of the racing I've done is small-block Chevy stuff...
I like the idea of bypassing the P/S pump, too. I'll try that on my donor if it has P/S. Cheaper than even buying a salvage non-P/S rack or gearbox!
Well, I knew that I didn't know everything when I joined here. What I didn't know was what I didn't know...
The brake pedal is my enemy. The brake pedal is my enemy. The brake pedal...
