Old 12-24-2008, 02:15 AM   #51 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
It's not the best engine design in terms of making power - that's for sure. It's supposed to be an efficiency design, basically.
BTW, is that Cossie based on the 2.3 liter? (Pinto/Mustang engines)
It looks a lot like the engine that my old pit-boss used in his dirt track cars.
Old 12-24-2008, 09:26 AM   #52 (permalink)
Fokus - '12 Ford Focus SE
90 day: 33.73 mpg (US)
Lecksus - '03 Lexus RX300
90 day: 17.61 mpg (US)
Benzzzzz - '11 Mercedes Benz ML-350 4-Matic
90 day: 22.83 mpg (US)
Ezcape - '15 Ford Escape Titanium
90 day: 20.11 mpg (US)
It's Based on a english ford Kent block, was never in a pinto or a mustang as was anything that looked like it. I don't know what a Cossie is, in racing circles we don't call it a Cosworth, just a BDA which is a size/application designation 1600cc's Formula Atlantic, there are many others; BDD, BDH,BDX,BDJ,BDM, each one has a size and an application. Very good reliable engine. For the pump drive that you see there are diffrent diameters and or teeth to slow or speed up the pump so that it doesn't cavitate depending a RPM rquirements. For instance the BDA's top rpm is 9500, the little BDJ is 1100cc's and spins at 12,000rpm so a larger pully is used. this way we can adapt these for this electric motor drive we are speaking of.
"The Stone Age did not come to an end because we had a lack of stones, and the oil age will not come to an end because we have a lack of oil" ; His Excellency Sheikh Ahmed Zaki Yamani (Saudi Arabia Oil Minister from 1962 to 1986)
https://ecomodder.com/forum/em-fuel-...ehicleid=10608
Old 12-24-2008, 09:40 AM   #53 (permalink)
heres another pic and you maybe can see the drive
Old 12-24-2008, 01:27 PM   #54 (permalink)
Losing the MISinformation
Intrigued's Avatar
Quad Cam - '00 Oldsmobile Intrigue GX
Last 3: 25.94 mpg (US)
Lightbulb Learn something every day!
Originally Posted by guudasitgets View Post
Intrigued; Why are belt drive pumps a problem? Simplist thing on earth and they never slip and you can get all sorts of ratios in pulleys for them. Look at the Cosworth 4 cylinder BDA in the pic, click on it and you will see the small belt drive I'm refering to.
Wow. You learn something every day! I just haven't had the opportunity to delve into timing belt/chain stuff, other than replacement. Since I didn't get into the racing side, except for some occasional drag racing, I didn't know there were different pulley sizes for timing belt-related stuff, and so on. Underdrive v and micro-v crank pulleys and so forth, yeah, but then all of the racing I've done is small-block Chevy stuff...
I like the idea of bypassing the P/S pump, too. I'll try that on my donor if it has P/S. Cheaper than even buying a salvage non-P/S rack or gearbox!
Well, I knew that I didn't know everything when I joined here. What I didn't know was what I didn't know...
The brake pedal is my enemy. The brake pedal is my enemy. The brake pedal...
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 01:21 AM
Electric water pump Gregte DIY / How-to 96 05-08-2022 04:49 PM
Turning off electric hot water heater when not home? ZachUA Saving@Home 33 12-09-2009 10:51 AM
Water Meter for water savings!!! bennelson Saving@Home 3 12-11-2008 08:21 PM
Hot water from oil in the summer time. Xringer Saving@Home 11 09-06-2008 11:02 PM
