Old 01-04-2009, 06:50 AM   #32 (permalink)
The Atomic Ass
The Atomic Ass's Avatar
Overland - '24 Nissan Versa S 5MT
90 day: 38.7 mpg (US)
Originally Posted by MD2000 View Post
At full rpm on the e-tek motor, I can go 30 MPH.
The acceleration with current limited to 200A @48V is reasonable on a downhill standing start, pretty slow on flat ground, and very slow on an up hill start.
I will not try to start when stopped at a light as the people behind me will get nasty since I may cause them to miss the light with the slow acceleration.
I tend to use the e-wheel for cruising at 30 MPH with my gas engine off, and can get 30-40 miles on a charge.
In hub wheels without any gearing that would accelerate a caravan at reasonable speed would use 400-1000A, requiring a huge battery and high current controller, and as stated above, the unsprung weight issues could make handling on bumpy roads unsafe.
200A @48V is ~12.5hp. Please define "slow on flat ground".
I would not even attempt to run a vehicle as large as a Caravan with only 48V. When you step into heavy-weight vehicles, you need heavy-weight components. I would consider 300V to be the minimum voltage, and I would prefer to run at 700V+. At that level, 200A is good for ~180hp. And electric HP at that.
As for un-sprung weight, I'll say it again, I don't think that many people understand just how much weight there is there already, and can be done away with. The entire un-sprung assembly on your average Caravan weighs in excess of 100lbs.
