01-02-2009, 08:29 PM
#31 (permalink)
Master Modifier
Interesting thread.
Some real world experience to help bring things into perspective:
My Honda Insight has a drop down electrically powered wheel for EV operation.
I used a 4:1 reduction to a 12" scooter wheel.
Mikes Insight - MIMA Honda Insight Modified Integrated Motor Assist Tour De Sol
Finding The Best Hybrid Mix - MIMA Honda Insight Modified Integrated Motor Assist Tour De Sol
At full rpm on the e-tek motor, I can go 30 MPH.
The acceleration with current limited to 200A @48V is reasonable on a downhill standing start, pretty slow on flat ground, and very slow on an up hill start.
I will not try to start when stopped at a light as the people behind me will get nasty since I may cause them to miss the light with the slow acceleration.
I tend to use the e-wheel for cruising at 30 MPH with my gas engine off, and can get 30-40 miles on a charge.
In hub wheels without any gearing that would accelerate a caravan at reasonable speed would use 400-1000A, requiring a huge battery and high current controller, and as stated above, the unsprung weight issues could make handling on bumpy roads unsafe.
I hope to add an electric drive to my dodge caravan, but will do it with an e-wheel trailer.
E-wheel for any vehicle - MIMA Honda Insight Modified Integrated Motor Assist Tour De Sol
An idea that I will be pursuing soon as a drive system for converting any FWD vehicle to electric, is to use a modified Prius drive system and power Inverter, which can be purchased form a junkyard for $500-$1000.
EV Insight with a Prius heart - MIMA Honda Insight Modified Integrated Motor Assist Tour De Sol
This drive has an automotive quality forced oil lubricated dual electric motor drive with a built in 3:11 reduction and differential ready for the CV shafts to the wheels, and a liquid cooled high power AC drive inverter with regen. All that is required is to externally generate the 3 phase drive signals.
Happy new year, and keep on ecomodding, we need it.
01-04-2009, 06:50 AM
#32 (permalink)
200A @48V is ~12.5hp. Please define "slow on flat ground".
I would not even attempt to run a vehicle as large as a Caravan with only 48V. When you step into heavy-weight vehicles, you need heavy-weight components. I would consider 300V to be the minimum voltage, and I would prefer to run at 700V+. At that level, 200A is good for ~180hp. And electric HP at that.
As for un-sprung weight, I'll say it again, I don't think that many people understand just how much weight there is there already, and can be done away with. The entire un-sprung assembly on your average Caravan weighs in excess of 100lbs.
01-04-2009, 09:49 AM
#33 (permalink)
Don't forget controller and motor inefficiency: a combined guesstimate of 85% efficiency brings us down to ~10.6 hp, theoretical.
Also, 200A is the peak available. I can't speak for Mike's motor/controller, but the combination in my EV only draws peak currents at a relatively low RPM range (on level ground, when accelerating), and only when the controller is cool (built in thermal protection).
To answer your question: 10-17-2007 - First 0-50 km/h (31 mph) acceleration test run: 36 seconds (on the 225A controller). The ForkenSwift is maybe 150 lbs heavier than Mike's Insight.
I've since upgraded to a 400A peak controller, and that has dropped to 21 seconds (but it's much harder on the lead acid batteries to draw high currents like that). Even with 400A, I avoid driving the car in "normal" traffic (because its max acceleration is still so much slower than the average driver), sticking instead to lightly traveled side roads, or off-peak times on otherwise busy streets.
01-04-2009, 01:29 PM
#34 (permalink)
Could throw some capacitors in there to allow for some short term high amp draw, and would greatly improve your ability to use regenerative breaking.
http://benw385.vox.com/
'Blog' on the open source electric motorcycle project.
Please come visit and comment!
01-04-2009, 02:53 PM
#35 (permalink)
I think any capacitor that could hold that kind of charge, (we'll say, 5k watt-minutes?) Would probably be unreasonably expensive. But then again I can't claim to have priced such a thing. I only remember 4 years ago, when I was building up a stereo in my truck, looking at ultra-capacitors for the amplifiers. And there, I was looking at peaks of ~100A for <1 second. Even then prices were sky-high.
01-04-2009, 03:01 PM
#36 (permalink)
Wannabe greenie
300V+ gear is very expensive, and 300V is highly dangerous. You can put in an ADC 9" and 144V 1000A controller for far cheaper than a 300V setup.
Keep the transmission and you'll have much better than stock performance.
01-04-2009, 03:03 PM
#37 (permalink)
I forget what voltage you run the ForkenSwift at. Is it 48v or 72v? 400A doesn't have a lot of meaning without a voltage to go along with it.
01-04-2009, 03:19 PM
#38 (permalink)
I'm thinking in terms of building a vehicle from the ground up, not conversion. For conversion, performance is almost always a trade-off with cost.
However, in a properly-designed production vehicle, I would have the expectation of higher voltages, and thus, higher efficiency and performance.
Still, just stepping up to 144V is significant from 48V in terms of available power.
I am in the blue-print dreaming phase of an all-electric RV. It will have 700V+, should I ever get around to building it.
Also, as for safety? There are several thousand volts going through the ignition system of a traditional ICE, but very few people ever get shocked. As for me, I build tube-based amplifiers, some of which run 500-700v on the plates. Low-current DC, sure, but it's still enough to kill you should you take it across the chest. I've been shocked before, but never fatally. Left hand in pocket, always.
01-04-2009, 06:10 PM
#39 (permalink)
48V - same as Mike's car. That's why I offered the comparison. (Though I should have stated as much).
01-04-2009, 06:47 PM
#40 (permalink)
PaulH
Maxwell Ultracapacitors are used quite a bit for hard acceleration over several seconds, to protect battery packs. One guy has a blog about how he did it with a bunch of their ultracapacitors that they were selling on clearance (they were making a new version). He said it made the battery pack feel very stiff, meaning there was almost no voltage drop under acceleration. I don't remember where his blog is, but just do a search for maxwell ultracapacitors ev conversion or some such thing.
It is a very expensive option, though. You need like 50 - 100 of them, and they are around $100 each!
