Old 01-04-2009, 03:19 PM   #38 (permalink)
The Atomic Ass
The Atomic Ass's Avatar
Overland - '24 Nissan Versa S 5MT
90 day: 38.43 mpg (US)
Originally Posted by Clev View Post
300V+ gear is very expensive, and 300V is highly dangerous. You can put in an ADC 9" and 144V 1000A controller for far cheaper than a 300V setup.
Keep the transmission and you'll have much better than stock performance.
I'm thinking in terms of building a vehicle from the ground up, not conversion. For conversion, performance is almost always a trade-off with cost.
However, in a properly-designed production vehicle, I would have the expectation of higher voltages, and thus, higher efficiency and performance.
Still, just stepping up to 144V is significant from 48V in terms of available power.
I am in the blue-print dreaming phase of an all-electric RV. It will have 700V+, should I ever get around to building it.
Also, as for safety? There are several thousand volts going through the ignition system of a traditional ICE, but very few people ever get shocked. As for me, I build tube-based amplifiers, some of which run 500-700v on the plates. Low-current DC, sure, but it's still enough to kill you should you take it across the chest. I've been shocked before, but never fatally. Left hand in pocket, always.
