Old 01-09-2009, 12:07 PM   #870 (permalink)
bennelson
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
The turnbuckle mount is actually working surprisingly well. It's beefy and solid feeling. I am not sure about the whole "flex" thing.
Yes the original engine mount would have had more flex to it.
I was still planning on eventually replacing it with something else. Maybe I'll just work on it sooner rather than later.
I like the concept of a diesel heater (running biodiesel). It wouldn't drain the batteries, and would have a high heat output. Using it to heat the batteries is also a good idea, although you would have to get clever in how you run the air tubes, and it would have to use a heat exchanger to keep combustion by-products outside the car and keep burning fuel away from potential hydrogen gas from batteries.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
