Old 01-13-2009, 06:22 PM   #14 (permalink)
aerohead
Originally Posted by basslover911 View Post
The ones behind the tires (the ones on the pictures) are not steep at all, probably around 3 degrees.
The middle one (which is finished now) is more like 7 degrees or so.
Also, I don't have a complete belly pan yet (I have the oem one in front but nothing in the middle of the car yet). I am going to see how durable this diffuser is and if everything works good I will make the middle one in about two months or so (Since that one is bigger and is going to be a little more, probably around $40 or so).
basslover,there is a section in Hucho's book which covers research conducted on bellypans and diffusers.The rear mods do not perform up to their maximum potential if everything leading up to it is not paneled.So the addition of the middle panel should improve what you have.-------------Also,Hucho reports that undercar flow will stall and separate if the diffuser rises at an angle steeper than 2-1/2 degrees,so your sheetmetal may be a little "fast."
