Originally Posted by aerohead
Also,Hucho reports that undercar flow will stall and separate if the diffuser rises at an angle steeper than 2-1/2 degrees,so your sheetmetal may be a little "fast."
Oh really...
So if my belly screen dips below the axles and spare tire at about 10" above the road, then at the very back, it should still be pretty low -- probably around a foot. And likewise, any wheel fairings originating near the bottom of the rear wheels need to terminate only slightly higher than the origin.
So on my truck, I would "ideally" need to have a low shelf hanging below my tailgate??
