Old 02-05-2008, 03:45 PM   #82 (permalink)
cfg83
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
NoCO2 -
Originally Posted by NoCO2 View Post
cfg83:
That's really cool! Where did you go to get that made, I have been thinking of making a window decal similar to that, maybe something that said "Hypermiler" or just had the logo from the site on it.
Thanks, I just made it at home. It still looks bubbly up close, but the silhouette is great from a car-to-car standpoint. Just go to an auto store and get something like this :
PEEL-&-STICK WINDOW FILM
http://www.jcwhitney.com/autoparts/I...D:100000222719
I used the tint that was rated at 20%, which is limo-dark.
Go to a stationaries store and get a permanent-ink silver (or gold or white) calligraphy pen like the following :
Sanford Calligraphic Marker Style Calligraphy Pen, Medium, Metallic Silver Ink
http://www.officeworld.com/Worlds-Bi...SAN46120/08Q1/
Then do as follows :
1 - Print an image on a piece of paper. This will be the stencil/trace image. You want an image that has good contrast for the lines you are going to trace because the window tint makes it hard to see through.
2 - Tape the paper onto a mat that you can cut on.
3 - Cut out a piece of the peel-&-stick stuff and tape it onto the paper.
4 - Use the silver calligraphy pen to trace the image. The reason I use a silver pen is because it will be hard to "see" what you are cutting in the next step. It is hard to see because the peel-&-stick is designed to absorb light. Make sure the silver pen is not tracing into the image, otherwise you will end up with silver marks on your cutout. Also use a piece of paper to cover the image as you trace, otherwise you will probably smudge the image with silver pen ink.
5 - Use an X-Acto to start the cut into the image and finish it with a sharp pair of scissors.
CarloSW2
American Solar Energy Society
