Old 02-02-2009, 10:41 PM   #26 (permalink)
Big Dave
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
Double-ended motors are not overly common but they can be had.
I'd put the electric behind the tailshaft of the tranny. When I want to run straight-electric, I kick her into neutral and shut down the engine.
If you want to use the Benz engine, get the Benz tranny and modify the frame to support. Match a DIN block to a SAE bellhousing makes tax law look simple.
The 616 engine should bolt right up to the four speed out of a 240D. Nice thing about this rig is that it will be running just fine when the rest of the truck rusts out around it and you could put the engine/tranny in another truck and probably outlast it. One caveat: Benz parts are uber-expensive. Pay more and get a good engine. Hit MercedesShop - Mercedes Benz Parts and Technical Information for advice. They are seriously cheap-Charley and know all the good parts sources.
Ever thought about a late-model (1986) 5.7 GM diesel? By then GM had cured the head gasket leakage problem. Its a bolt-up on your T-5.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
