Thread: New Aptera
Old 02-03-2009, 11:14 PM   #70 (permalink)
NeilBlanchard
Hi,
They now are aiming for October 2009 for production, which is a full year later than they had originally intended. It is a complex machine, and there are a lot of bits to nail down; like a battery supplier.
They have released a lot more details and specifics about the 2e, at the TED conference, where they are offering rides, as well.
Official dimensions: 53" high x 91.0" wide x 173" long.
More specs from sheet:
111" wheelbase
80.5" front track.
0.15 Coefficient of drag
5" ground clearance
1500 lbs curb wt.
Electric motor torque: 60FtLb torque
110v 15A charge time: 8 hrs.
Battery output: 10-13 KWh battery pack.
Battery voltage: 336V DC Nominal Traction Voltage
Transmission: Gear box 10:1 ratio
- Battery Type: Lithium Ion Phosphate.
Chassis:
- Front Suspension: Independent unequal length A-arm
- Rear Suspension: Swing Arm
- Steering: Manual Steering, tilt steering column
- Brakes: Manual Brakes, dual circuit brake hydraulics, mechanical brake proportioning, 3-wheel disc
- Wheels: 14-inch High Strength Stamped Steel wheels
- Size: P165/65R14
Performance:
- Range: Up to 100 miles per charge
Warranty:
- Basic: 4/50,000
- Powertrain: 4/50,000
- Corrosion: 12/unlimited
- Roadside: 4/50,000
Features: (S=standard, O=optional)
Interior:
Push Button Start: S
Electronic shift PRNDL (shift controller): S
AM/FM/MP3/WMA with 5 speakers and MP3/Smart Phone Connectivity: S
DVD Navigation System: O
Power up/down windows with Driver side one-touch and anti-pinch: S
Power automatic door locks with anti-lockout feature: S
Center console armrest with two cup holders: S
Overhead mounted LED Dome Lights: S
Recycled Fabric-trimmed seats and door panels: S
Leatherette (recycled materials) trimmed steering wheel: S
Defroster-linked CFC-free automatic climate control with electric inverter compressor air conditioning: S
One 12V auxiliary power outlets and One 12V USB Outlet: S
Retractable passenger-assist grips at all doors: S
Exterior:
Dual color-keyed power outside mirros: S
Aerodynamic multi-reflector halogen headlamps: S
Washer-linked variable intermittent windshield wipers: S
Rear window defogger with timer: S
Rear Electronic rear hatch locking system (sic): S
Solar Energy-Reflecting glass: S
Smart Key System (Proximity locking/starting) Maintenance key & cylinder to prevent accidental lock out: S
Safety:
Remote keyless entry system with 2-stage unlocking, panic function and remote illuminated entry: S
Backup camera: O
Driver and front passenger Airbag System: S
Front and rear crumple zones and side-impact door beams: S
Engine immobilizer: S
Center high-mount stop lamp: S
Emergency Tire inflation system: S
3-point front outboard seatbelts with adjustable shoulder anchors and driver-side Emergency Locking Retractor (ELR), front passenger Automatic/Emergency Locking Retractor (ALR/ELR): S
Driver and front passenger seatbelt with seat belt starter interlock: S
Direct Tire Pressure Monitor System (TPMS): S
Anti-theft system: O
Here's some more pictures from the TED conference:
Some more pictures from TED - ApteraForum.com - Aptera Car Forum
Found 2 Apteras waiting for TED. MEASUREMENTS & Pics! - ApteraForum.com - Aptera Car Forum
There should be a video up pretty soon, too.
