ANDERSON connector, that's the name I was looking for...
The brushes on the drive motor look a little different then they did on the pump motor.
I haven't gotten the end off yet, so I can only peak thru the view port/air hole.
The brushes are straight, they were angled on the pump motor.
It looks like the drive motor only has one brush in each position. Am I seeing it wrong?
