Old 02-21-2009, 03:05 PM   #11 (permalink)
Intrigued
Losing the MISinformation
Intrigued's Avatar
Quad Cam - '00 Oldsmobile Intrigue GX
Last 3: 25.94 mpg (US)
Originally Posted by Piwoslaw View Post
...those two thing could/should be coordinated? If I want to P&G my A/C, then is it better to turn it on while while the car is already under power during a pulse, or when I'm coasting in neutral? I turn off the A/C when I really need power, like uphill or passing a truck, and turn it on when engine braking. But during P&G in normal conditions when is it better to put an extra load on the engine?
If I am in traffic, and can't really P&G, I turn my A/C off going uphill, and work hard to keep my torque converter locked in. I turn it on as needed going downhill, especially if the hill is too steep and I need the extra braking.
When there isn't a lot of traffic I run the A/C during a neutral coast, but I may have to try using it during the Pulse. Sometimes it's real easy to assume one way works better...
The brake pedal is my enemy. The brake pedal is my enemy. The brake pedal...
