Old 02-24-2009, 03:40 AM   #14 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
Just in case you didn't know... 12.2 resting voltage is about the lowest you will want to go with anything other than a true deep cycle flooded battery. Any lower will kill the battery quick. Also you should charge it up every chance you get. Leaving a battery partly discharged will lead to sulfation.
You might want to invest in some more batteries which will allow them to last far longer especially for long trips.
I strongly encourage you to read up at Battery University if you have not done so.
Lead-acid does not lend itself to fast charging. Typical charge time is 8 to 16 hours. A periodic fully saturated charge is essential to prevent sulfation and the battery must always be stored in a charged state. Leaving the battery in a discharged condition causes sulfation and a recharge may not be possible.
Lead-acid does not like deep cycling. A full discharge causes extra strain and each cycle robs the battery of some service life.
Absorbed Glass Mat Batteries (AGM)
Cannot be stored in a discharged condition - the cell voltage should never drop below 2.10V.
Allows only a limited number of full discharge cycles - well suited for standby applications that require only occasional deep discharges.
Alternatorless driving will pay for itself as long as you treat your batteries well.
Cheers.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
