Old 02-25-2009, 02:18 PM   #50 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Another option??
If "cheap, immediate" replacement is truly the issue, a small used Corolla (gas/manual tranny) may be what you need. You pay a premium for the extra technology in either the Prius or TDi that could take years to recoup through fuel savings alone. Used Toyota gassers should be plentiful and reliable even if they give up a little in ultimate fuel economy.
If you want fuel economy and performance too, get the TDi.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
