I love the idea of a smart charger which would have some adjustments for amps and volts.
One down-side of the gel-cell batts. I am using right now, is that they require being charged at a little bit lower voltage. (higher voltage cooks the gel electrolyte!)
With a smarter open-source charger, the same charger design could be used no matter what style battery - AGM, Gel, Flooded, etc. is used.
