Old 02-26-2009, 04:55 PM   #8 (permalink)
dieter.pareyn
You may laugh at the 'bold' tires but (i don't have a clear view on them of course) they seam to be worn mainly on the outside. If this is the case maybe you should get you're car alligned again. If you're car isn't properly allignd it will also increase you're fuel use (and you're tires ware of mor rapedly as well).
grtz Dieter
