Old 06-10-2008, 08:46 AM   #1 (permalink)
BBsGarage's Avatar
BBsRide - '06 Toyota Corolla CE
90 day: 31.64 mpg (US)
Front Wheel Deflectors
Well I finally got to add front wheel deflectors.
I decided to just extend the ones that were currently on the car so they actually cover the wheel.
They are made of an old mud flap That I had sitting around.
First impressions are that the car coasts slightly better, but I will have to wait till I burn through a few tanks of gas before I know if they help any.
Here are a cpl of pics.
Thanks.
Bill
SippingFuel
Check out BBsGarage
Picture ur Pet
Old 06-10-2008, 05:40 PM   #2 (permalink)
Future EV Owner
Wannabe - '05 Honda Civic LX
90 day: 40.53 mpg (US)
They look really good. I think it will be hard to measure the improvement, but they will help anyhow.
Old 06-10-2008, 06:33 PM   #3 (permalink)
Old Retired R&D Dude
Little Red - '12 Toyota Prius c 2 Two
90 day: 57.82 mpg (US)
"Whitey" Bulger - '14 Toyota RAV4 LE
Looks like a Pop-Rivet in there. Nice and neat.
Is that rubber stiff enough so it won't be vibrating as you drive?
I was worried about the floppy factor and I've been looking at using
some real solid 1/8" G-10 (fiberglass) board..
I was also thinking about the angle. Most of these little wheel dams,
seem to be flat to the air flow.
I wonder if it would help if the dam was mounted at an angle?
Allow the air to fall off to one side maybe?
But which side? Outside the tire or under the car?
Cheers,
Rich
Current ride: 2014 RAV4 LE AWD (24 MPG)
Wife's Pizza Transporter
Old 06-11-2008, 07:54 AM   #4 (permalink)
BBsGarage's Avatar
It is made from an old mud flap that I had sitting around so it is plenty stiff.
I thought of using pop-rivets, but instead I used some wide head sheet metal screws.
Thanks.
Bill
SippingFuel
Check out BBsGarage
Picture ur Pet
Old 06-11-2008, 08:33 AM   #5 (permalink)
Harebrained Idea Skeptic
The White Car - '84 Mercedes-Benz 300td
90 day: 28.84 mpg (US)
The Blue Car - '86 BMW 535i
Last 3: 23.86 mpg (US)
Do your bald tires offer less drag?
Old 06-11-2008, 08:48 AM   #6 (permalink)
vectra a - '95 Opel Vectra GLS
90 day: 37.51 mpg (US)
looks a bit like what i had for a while on my prev car, wasn't as well made though.
the car felt much more stable with them, but i didn't have them long enough to see any FE improvement.
let is know what the resuly is, as i might build something similar for my curent ride
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
Old 06-11-2008, 11:00 AM   #7 (permalink)
BBsGarage's Avatar
c'mon theres only 60k miles on them, theres plenty of life left
Thanks.
Bill
SippingFuel
Check out BBsGarage
Picture ur Pet
Old 02-26-2009, 03:55 PM   #8 (permalink)
You may laugh at the 'bold' tires but (i don't have a clear view on them of course) they seam to be worn mainly on the outside. If this is the case maybe you should get you're car alligned again. If you're car isn't properly allignd it will also increase you're fuel use (and you're tires ware of mor rapedly as well).
grtz Dieter
Old 02-26-2009, 08:13 PM   #9 (permalink)
Hi,
I think you'd see a large improvement with some smooth wheel covers, on those steel wheels.
DIY: plastic rear wheel skirts (Geo Metro) MetroMPG DIY / How-to 57 06-12-2014 09:16 AM
DIY Rubber Front Wheel Skirts newtonsfirstlaw DIY / How-to 32 05-19-2011 07:45 AM
Suspension Dams on Production Cars Arminius Aerodynamics 19 08-13-2008 02:49 PM
Front wheel well air deflectors? kevlar EcoModding Central 0 05-18-2008 06:21 PM
Why not use this for undertray wheel deflectors & fairings? Otto Aerodynamics 6 04-07-2008 01:48 AM
