If both of the stereos are outputting the same volume, the difference is probably nil -- not worth worrying about.
If you're concerned about weight, have you looked at your own bodily weight? Reducing that will bring benefits to any vehicle you ride in, and consuming less will mean fewer trips to the grocery and overall less impact to the environment.
