Old 03-06-2009, 06:46 PM   #14 (permalink)
some_other_dave
If you use a simple swing-arm rear suspension, you could put the drive sprocket on the same axis as the swing arm pivot point. That way there is no need for a tensioner on the chain. (Or, keeping in mind that the real world means having to allow for some extra movement, it means you don't need as much of a tensioner.) Perhaps motorcycle swing-arms would work. They have a chain (or belt!) drive that has been very thoroughly worked out.
-soD
