Old 03-10-2009, 03:47 PM   #5 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Originally Posted by PaleMelanesian View Post
Remember, too, that larger diameter tires will have much worse rotational inertia. Nearly all the mass of a tire is on the outer diameter, at the tread / steel belts. Any time you change speeds, it'll be working against you - massively.
Ooh, right. I forgot that one.
Good tip on the transmission internals.
