Made a tray to fit the two batteries that go behind the seat. The way the caps are made it won't be hard to attach a hose to them to vent them under the car. I will probably make a cover of some sort to hide them. They don't look that good back there.
The controller and battery charger should be in tomorrow. I decided to get a jump on spring break and start on some of the easier things today. I have some time tomorrow so I will try to get the rear battery tray built and stick a different set of springs under it to get it sitting level again. Hopefully this weekend I will be able to get the sprockets and motor mounted up. I am thinking of taking the dashboard out when I wire up the controller. There are a few issues I need to look at anyway and it would be a good time to get everything sorted out and working.
