Old 03-11-2009, 08:31 PM   #16 (permalink)
ConnClark
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
The stock SMIC is a restriction on a stock 1.8t engine. It has as much as 3 psi drop across it. That is way to big of a drop even if it is floored.
The reduction in intake temps will occur any time your on boost.
An increase 2 to 4 hp on a 90hp engine with the same maximum fueling is still better than a 2 to 4% improvement.
