Old 03-11-2009, 08:56 PM   #18 (permalink)
tasdrouille
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
Originally Posted by ConnClark View Post
The stock SMIC is a restriction on a stock 1.8t engine. It has as much as 3 psi drop across it. That is way to big of a drop even if it is floored.
I agree with the 3 psi figure as I measure it myself on my car. But as you said it, only when floored. How much of your driving time do you go flooring it?
The reduction in intake temps will occur any time your on boost.
That I completely disagree. I was not able to find a difference in IAT under highway steady state driving, when boosting between 2-4 psi, wether I had a stock setup or completely blocked cross flow to the IC. So I doubt an after market IC would do much better.
An increase 2 to 4 hp on a 90hp engine with the same maximum fueling is still better than a 2 to 4% improvement.
I agree, but don't count on any improvement other then when you have the pedal to the metal, be it in regards to power of FE.
www.HyperKilometreur.com - Quand chaque goutte compte...
