Old 03-12-2009, 06:00 PM   #566 (permalink)
NiHaoMike
Originally Posted by nubie View Post
can't or don't? Or maybe I'm not human?
@Paul, don't let surface-mount stop you, there are many many benefits to surface mount.
If you are just worried about soldering to the surface-mount chip then get a Schmart board ( SchmartBoard - The world's best circuit prototyping system ) or a dip adapter and have somebody else do the SMD soldering.
SMD soldering isn't all that hard, you just need a steady hand, keen eye, and a nice sharp ~15watt iron. Here is my PCI-e x1 video card with a repair because I was over-zealous with the dremel.
I would have used a scalpel to remove the insulation over the damaged trace and then soldered a strand of wire across it. Keeping the signal lines as close to the same length as possible is very important in high frequency circuits.
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
