Originally Posted by MazdaMatt
"most" people can't fix "most" of today's electronics. and by most, i mean 99.99% of people.
Yeah, I just got commended for that soldering by "Shamino" Tan on the VR-Zone forums, he holds several world records for overclocking
shamino tan - Google Search .
Originally Posted by NiHaoMike
I would have used a scalpel to remove the insulation over the damaged trace and then soldered a strand of wire across it. Keeping the signal lines as close to the same length as possible is very important in high frequency circuits.
Yes I did realize that, but it has been in use for over a year now (notice that photo is from 2007). Also the standard has been raised to "2.0" and received a near double boost in mhz, so for a version 1.1 link this is fine.
I would have done the as you suggest, if not for the fact that I needed the clearance so that it would fit in a PCI-Express x1 slot and the traces on the low-profile card were running through that area (I also managed to cut the +12v lead to the DDR2 power circuitry hidden on an internal power layer, but reconnected it externally).
nice fix  add some hot glue for longevity! Why on earth did you attack it with a power tool?
To sum up, PCI-e buses are teamed serial connections comprised of 1 to 32 "links" (desktop PC's have at maximum 16 links per connector
http://www.naplestech.com/shopcart/bus_speeds.asp ). I wanted to hook up multiple displays with cheap readily available cards (and not saturate my PCI bus).
I learned that the PCIe standard auto-negotiates links and determined that I could operate a card on a single link. If I had any motherboards with a x4 connector I would have likely tried that, but x1 is the "standard".
Now that we are way off topic, I guess if Paul needed any SMD soldering done I could help out, but I am in California so it isn't the quickest way.
