Old 03-13-2009, 09:58 PM   #569 (permalink)
NiHaoMike
Originally Posted by nubie View Post
To sum up, PCI-e buses are teamed serial connections comprised of 1 to 32 "links" (desktop PC's have at maximum 16 links per connector NTI--PCI vs PCI Express / Bus Speeds ). I wanted to hook up multiple displays with cheap readily available cards (and not saturate my PCI bus).
I learned that the PCIe standard auto-negotiates links and determined that I could operate a card on a single link. If I had any motherboards with a x4 connector I would have likely tried that, but x1 is the "standard".
A better solution is to just take a piece of bare wire (AWG22 or so), heat it up with a soldering iron, and use it as a hot knife to open the back of the slot. Then you don't need to modify the card at all.
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
