Old 03-14-2009, 11:04 PM   #70 (permalink)
Coyote X
nut
Coyote X's Avatar
Metro XFi - '93 Geo Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 Suzuki DR650SE
90 day: 55.26 mpg (US)
Send a message via MSN to Coyote X
Plasma cutter decided to die today so I didn't get much done. I ended up using a chop saw and angle grinder to make the motor mounting plate. Not pretty but I don't want to wait for a week for my plasma cutter to get fixed.
I got half the frame made up for mounting the motor. The adjustable side isn't done yet. I don't think I need much of an ajustment range but a little bit would be good. I will probably redo most of this later one once I cut some nicer looking and fitting parts out with my plasma cutter but for now it will do just fine.
After finishing up the bracket I just have to remount the radiator and MSD module and assemble the axle properly. Then it is just a matter of wiring it all up and seeing what happens.
