Originally Posted by PaleMelanesian
Are those tires wide and sticky? They're hurting your mileage. Narrower (closer to stock) tires and low Rolling Resistance tires will help.
I guess they are pretty wide, 205-50-R15's. Once these run low, I can put on some 195's (smallest tire for my rim size).
Higher pressure will also help. I recommend the sidewall max (or more)
Always
