Old 03-24-2009, 09:20 AM   #11 (permalink)
The Crimson Crawler - '04 Hyundai Elantra GLS
90 day: 36.71 mpg (US)
Put that Kammback and rear skirts on it, and people will think it's a convertible Insight or a CRX! I LOVE the look!
Old 03-24-2009, 10:02 AM   #12 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
I think you'd be fine with a Kammback that came down to the back end of the trunk. The angle would be a little steep, but not too bad. It would be easier to make, for sure.
Are those tires wide and sticky? They're hurting your mileage. Narrower (closer to stock) tires and low Rolling Resistance tires will help. Higher pressure will also help. I recommend the sidewall max (or more).
Old 03-24-2009, 12:58 PM   #13 (permalink)
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
Hm...interesting... me likey.
Old 03-24-2009, 01:13 PM   #14 (permalink)
jedi_sol's Avatar
Subaru
Sports Cars
Team Turbocharged!
I guess they are pretty wide, 205-50-R15's. Once these run low, I can put on some 195's (smallest tire for my rim size).
Always
Old 03-24-2009, 01:45 PM   #15 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Originally Posted by jedi_sol View Post
I made a quick MS Paint mockup, does this look about right?
I like it!
You can ultimately go steeper than that if you use an arc. It's the sudden transitions that are a problem.
Have a look in this thread at the "teardrop" template that Phil (aerohead) espouses. (You can get away with steeper angles than the teardrop, but then you also need to have aggressive taper in plan view to keep flow attached)
http://ecomodder.com/forum/showthrea...sion-3518.html
Old 03-25-2009, 12:24 PM   #16 (permalink)
gascort's Avatar
Gascort RIP - '93 Ford Escort Wagon
90 day: 43.01 mpg (US)
WifesCruze - '11 Chevrolet Cruze LT
90 day: 31.1 mpg (US)
I like the Kammback'ed Del Sol idea.
Welcome to EM!
Gasoline, Wind, Solar, Gravity Hybrid-to-be! http://www.scientificmethodfueleconomy.blogspot.com/
Old 03-25-2009, 12:57 PM   #17 (permalink)
X-Frenchy: very
groar's Avatar
scenic - '01 renault scenic
90 day: 43.09 mpg (US)
megane - '97 renault megane classic
Diesel
90 day: 72.53 mpg (US)
dennisius - '06 Toyota Prius
90 day: 69.27 mpg (US)
Hello jedi_sol and welcome on-board.
Rear wheel skirts are easy to do with cardboard or coroplast.
You didn't talked about your driving style. Since I pulse & glide (in neutral, engine on) I improved a lot: the secret is to wait, wait, wait...
I installed coroplast rear wheel skirts at the beginning of the current tank and I can feel the car coasting longer. I also feel it more nervous and my "fast accelerations" habits are coming back but I will beat my records
I'm dreaming about a kammback, but I'm afraid tape will not be enough to keep it securely attached.
Have fun,
Denis.
Save money & CO2 at home : http://ecorenovator.org/
Created and managed by the creators of http://ecomodder.com/
Earth and health are priceless, so are kilotank and AT-PZEV
Best Mégane tank: 1268.9mi @ 77.847 MPG(US)
2008/06-2011/10 saving:
  • 5725.5 kg CO2 (5342.6+382.9)
  • Diesel / Money: 42.17% = 2446.25€ = 3357.26$
megane : thread - kill switch.
Old 03-25-2009, 03:00 PM   #18 (permalink)
jedi_sol's Avatar
Subaru
Sports Cars
Team Turbocharged!
Thank you everybody for all of your input.
One question I have is with any future mod i decide to do, since i do not have a scangauge to give me real time results, are there another testing methods I could use to see if the mod is helping/hurting?
Old 03-25-2009, 03:06 PM   #19 (permalink)
You probably saw that krousdb used a SuperMID MPG computer in his car. You can buy or build yourself an equivalent: check the MPGuino subforum & wiki here on EM.
Old 03-25-2009, 04:06 PM   #20 (permalink)
Hypermiler
Wagons
You could try some coast-down tests. They'll show you the aerodynamic benefit. How much that affects your mileage is still a question, but an aero improvement almost guarantees a mileage improvement.
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
EG seat swap Del Sol n2 EG Civic Nden DIY / How-to 6 04-02-2010 02:30 AM
fs: san diego honda del sol d15z1 VX Civic 50+mpg CALIFORNIA BAR Certified conversion fistopher For Sale 26 08-01-2008 07:43 PM
aeromodding del sol track car MazdaMatt EcoModding Central 8 07-23-2008 05:51 PM
CL: Mechanic's Special 95 Honda Del Sol Red For Sale 0 04-16-2008 02:38 AM
