Old 03-24-2009, 01:45 PM   #15 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Originally Posted by jedi_sol View Post
I made a quick MS Paint mockup, does this look about right?
I like it!
You can ultimately go steeper than that if you use an arc. It's the sudden transitions that are a problem.
Have a look in this thread at the "teardrop" template that Phil (aerohead) espouses. (You can get away with steeper angles than the teardrop, but then you also need to have aggressive taper in plan view to keep flow attached)
http://ecomodder.com/forum/showthrea...sion-3518.html
