Old 03-30-2009, 05:59 PM   #710 (permalink)
bennelson
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
OK, I know this might be a bit wild, and I am typically for things being simpler, not MORE complicated, BUT.
What if you made the controller with an ethernet jack and could run that to a Scangauge? The ScanGauge gives you engine (motor) RPM, coolant temperature (motor temp!?) and lots of other cool information.
If you could create a data output from the DIY controller that would output info in a way the Scangauge could interpret, you would have a pre-made instant-read display! Plus, lots of us already have Scangauges!
Otherwise, a controller output to an MPGuino would be super-slick as well!
In the mean time, I will stick to my analog ammeter and voltmeter.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
