Old 04-01-2009, 10:38 AM   #4 (permalink)
brucepick
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Sounds like a good commute. Remind me again how you're monitoring lean burn?
How long to the next fill-up? Please post back here so we know the actual outcome.
I have another approx. 200 miles left on this tank. I'm also temporarily off work awaiting a contract extension and also a new contract, so it could be a while to the next fillup.
I monitor Lean Burn status on the ScanGauge. Here's how to program it. Of course the procedure makes no sense if you don't have a SG or you don't have it's manual that gives you the basics of programming its X-Gauge options. Given those basics, one can do this.
TXD: 686AF10115
RXF: 044105150000
RXD: 2808
MTH: 000100020000
NAM: LBN
and save.
If the value for LBN = 0 you are in lean burn.
here's what I monitor on the SG
Coolant Temp - - - - - - - - - - - - Throttle Position
(due to grill block) - - - - - - - - -(LB kicks out at 32 TPS)
MPG or Intake Temp - - - - - - - - Lean Burn Status
(cold intake kills LB)
Coast long and prosper.
