Originally Posted by Coyote X
The way it works on a metro is to just drill a new indexing hole halfway around the sprocket. Just make it half a tooth off for 9 degrees since a full tooth off is 18 degrees
Crankshaft sprocket, right?
Does a roll pin or some such go through the indexing hole?
No keyway?
FWIW Already skimmed through
http://ecomodder.com/forum/showthrea...html#post26075
If a moderator happens to read this, please change the title of this thread from
FE Cam Regrinds : General Info to
Cam Timing and Regrinds : General Info
