Old 04-14-2009, 04:56 PM   #66 (permalink)
MetroMPG
90 day: 57.73 mpg (US)
Originally Posted by bwilson4web View Post
Thanks! A few questions:
  1. How much warm-up time and speed before the first "A" test? (Prius warm-up is ~30 min., thermal changes takes about 5-10 minutes.)
The day of the test, the max temp was 18C - I didn't record the actual early evening temp when I ran the test. It takes me 20-25 minutes to get to the test route (combination of sub/urban and rural driving). The car may also have already been warm prior to setting out (didn't make a note of that).
How much warm-up time before the first "B" test?
The airtabs were attached with tape in approximately 2 minutes. The engine was left on during this.
How much warm-up time before the second "A" test?
It would have taken less than a minute to remove the tabs, engine left running again.
How many minutes per run?
1.6 km at 90 km/h for the run itself (~64 sec), plus time getting up to speed, plus time coasting to a stop, jotting down the run data & turning the car around. 2-3 minutes per run is probably a good guess.
Are the vortex generators still available?
Yes. I can send them to you if you like. PM me your mailing address.
