Old 04-14-2009, 06:46 PM   #26 (permalink)
skyl4rk
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Toyota Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Versa Sedan 1.6 Base
90 day: 41.69 mpg (US)
The crazy wingtail idea:
I'm still not sure if I can get it to work. The trunk is not closing easily. The taillight wires are a little too short. I need to trim the tabs that jam fit into the rear doors. I need to recut the lower panel which is clamped using binder clips to the rear bumper and maybe find a better way to hold it on the bumper. I'm not sure if the thing will stay on. I'm not sure if it will wobble.
This is "See If It Falls Off Engineering".
Nissan Versa Aeromods
The Following User Says Thank You to skyl4rk For This Useful Post:
HHOTDI (01-18-2013)
