Old 04-14-2009, 10:06 PM   #79 (permalink)
MetroMPG
90 day: 57.73 mpg (US)
Originally Posted by theunchosen View Post
Any fan coupled with standard draws will overrun your supply forcing the alternator on anyway and then you are hauling around a solar panel for no real reason.
Not true. The alternator will only output as much power as needed to maintain a given battery voltage. If the panel is contributing, say 50% of your electrical load requirements, the alternator's voltage regulator will look after ensuring the alternator only makes up the difference. There will still be a fuel savings.
