Old 02-15-2008, 12:44 AM   #15 (permalink)
RH77
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Originally Posted by Coyote X View Post
I can't find the link on here but there was a discussion about adding a flapper to the end of the tailpipe. Jegs sells one that is pretty cheap and could have a spring fit to it to adjust the amount of pressure required to open it. Putting it at the end of the exhaust is not as good as closer to the front but I am sure it will still help out.
I'd love to see the results of such an addition. I would definitely consider one if it worked properly and results were solid.
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
