Old 04-16-2009, 02:45 PM   #85 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by captainslug View Post
Yesterday I got punched in the wrist by a vice stuck in a drillpress. It doesn't look like much, but it's tender. Probably just a deep tissue contusion.
It happened while I was trying to drill out the small pulley to match it's ID to the drive shaft of the motor. No surprise it getting stuck in the drillpress screwed it up, so I have to try again. But this time around I'll do it the careful way by using the lathe. Zinc, much like brass, can be fussy stuff to work on.
I used to inject-mould zinc... at 830*, it doesn't even burn when it touches you. It sears. Instantly.
It's very hard though. Even foils of Zinc can withstand pressures that exceed what you think it should be able to hold. That's probably why they use it on cables and flexible drive assemblies.
