Originally Posted by Frank Lee
Holy Mackeral, are you sure about all that???
I pour it in the tank and go. Anything after '88 or so will run on it, but expect some driveability issues if you go straight E85 in sub-freezing weather. I have found at concentrations of 50/50 or less E85/regular, there are no driveability issues and the fuel economy doesn't drop very much if at all.
I'm with Frank on this. I can run E50 with out much loss in FE. I been running a mix of E15 for quite a while, with no mods to the car, which give me better FE then straight gas.
