Old 04-22-2009, 11:16 AM   #1 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Honda is developing a variable compression automobile engine: MPG up 7.4%
Source: Green Car Congress: Concept: Honda RD Developing Variable Compression Ratio Engine with Dual Piston Mechanism
In testing in an otherwise conventional production 2.0-liter, 4-cylinder engine, the dual piston mechanism was able to adjust the engine from a CR of 9.6 to 14.2 and back again. Combining the high compression ratio with the Atkinson cycle, the engineering team demonstrated a 7.4% improvement in fuel economy in operation over the Japanese 10-15 cycle.
They realized the movement of the dual piston mechanism by inertia and external hydraulic pressure, with the result that...
...in contrast to the complexity, size and power demands of earlier VCR concepts, [Honda engineer] Kato said, the new dual piston VCR could be installed without changing any of the major parts of the engine such as the engine block.
  • The ratios are set at "high" and "low", though, not a range between the two.
  • The engine was durability tested to 1 million cycles.
  • Honda sees an efficiency advantage to this approach vs. turbo/supercharging a smaller displacement engine.
  • Details are available in an SAE paper on the subject, presented at the SAE 2009 World Congress
