Old 06-02-2010, 10:44 AM   #11 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
I wonder... is there any way to use the ScanGauge to tell when the ECU has started enriching the mixture due to excessive throttle position? Obviously full throttle open loop is one sign, but are there earlier indications, such as ignition timing?
Old 06-02-2010, 04:52 PM   #12 (permalink)
toyota corolla - '99 toyota corolla ce
90 day: 38.97 mpg (US)
Originally Posted by PaleMelanesian View Post
Lower rpm is better. 5th gear is better, until the point where you cannot maintain the speed needed.
perfect , thanks for answer
graphic:http://ecomodder.com/forum/em-fuel-l...vehicleid=3083
lowered -1.5 inch .
+80 pound (approximation) of audio (and draw a max of 20-25 amp approx..)(ouch for alternator !!)
Old 06-02-2010, 07:06 PM   #13 (permalink)
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Mercury Villager gs
90 day: 19.8 mpg (US)
Lyle the Kindly Viking - '99 Volvo V70
90 day: 25.82 mpg (US)
I think full throttle will be the tell tale sign, not much more complicated than that.
a favorite guage of mine is the LOD guage, which tells you the load percentage on the engine. I would assume keeping the LOD guage high in top gear when you need the power is the way to go..Too much on an auto, though, and you downshift.
RIP Maxima 1997-2012
Originally Posted by jamesqf View Post
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
Old 06-03-2010, 09:11 AM   #14 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
That's just it, the loop gauge. I find that Open Loop happens consistently at >95 LOD on my car.
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
Throttle sensitivity Formula413 EcoModding Central 13 05-29-2008 04:55 PM
