Old 07-07-2011, 09:39 AM   #1 (permalink)
Muscle Car Modder
Floordford's Avatar
QuikSilver - '00 Ford Mustang GT
90 day: 24.7 mpg (US)
Acrylic or Lexan wheel covers
Has anyone tried to use hard clear plastic as wheel covers?
I thought of this option for my Mustang because I have 17" 5 spoke wheels that wont accept a hubcap. And a Mustang would probably look a little odd with shiney moon disks. Clear covers would let you still see the rim and give the benefits of a cover. I had also thought about trying to heat it up to get a convex shape. Might work, might not.
2000 Mustang GT
273hp/ 309ft.lbs.
Cd 0.36 Im working on it
Old 07-07-2011, 10:45 AM   #2 (permalink)
Making Ecomods a G thing
Angie - '08 Infiniti G35 X
90 day: 22.03 mpg (US)
It would definitely be more asthetically pleasing to have. Not sure what the best way would be to attach them. You could glue them in place with some gorilla glue, though that would make removal difficult.
Old 07-07-2011, 11:48 AM   #3 (permalink)
Muscle Car Modder
Floordford's Avatar
I was thinking of removing my center cap, because its costly to replace, and from the back side make a round threaded fixture that I can run a small bolt to. I think that might be the best so it wont throw the balance off.
2000 Mustang GT
273hp/ 309ft.lbs.
Old 07-07-2011, 12:27 PM   #4 (permalink)
kir_kenix
kir_kenix's Avatar
1997 Chevy s10 - '97 Chevy S10 WT
Pickups
90 day: 32.71 mpg (US)
1997 Ford Escort - '97 Ford Escort LX
Team Ford
Last 3: 32.29 mpg (US)
Razz - '97 Yamaha Razz
90 day: 109.57 mpg (US)
2004 Ford F250 - '04 Ford F250 XLT
90 day: 16.32 mpg (US)
2000 S10 4.3 - '00 Chevrolet S10 W/T
Pickups
90 day: 19.4 mpg (US)
2010 corilla - '10 Toyota Corolla LE
90 day: 32.82 mpg (US)
'Yota - '22 Toyota Rav4 LE
90 day: 37.41 mpg (US)
This is exactly what I did on my steelie wheels to attatch pizza pans. I made a little spacer on the rim side so the pans had something to torque down against. I had to cut the pizza pans on the edge to fit around my wheel wts and this has kept them from moving once torqued down. I also used purple locktite to keep the bolts from loosening up over time.
I had this set up on my ride for about 5k miles before having to take them off to get tires rotated and I havn't put them back on yet. This time I'm going to find some stainless hardwear so the bolt sticking out doesn't rust as bad.
I really thought that they would end up in the ditch at some point from the center bolt loosening up over time, but this became a non issue for me. I think the same process would work great with lexan, and look better to boot! Probably will have to take them off from time to time to clean all the break dust off the back side however.
Good luck man.
Old 07-07-2011, 02:11 PM   #5 (permalink)
Phantom's Avatar
Blue Meanie - '02 Volkswagon Golf TDI
90 day: 48.52 mpg (US)
Wife's car - '05 WV Passat TDI
Rudy - '94 Chevy C2500
If you use lexan or acrylic I would wax it to keep the dust down. I have thought about how it mount covers if I want to keep the look of the wheels. I think that it could work if the rim was removed and a round cover was attached to the inside of the rim then remounted.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
Old 07-07-2011, 02:21 PM   #6 (permalink)
acrylic will stay clear, is cheaper but more brittle than lexan (polycarbonate).
Old 07-07-2011, 02:25 PM   #7 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Acryl wont work because its brakes at impacts. Material needs to be polycarbonate or was it polyester PETG, PET that works also. Here is what I can manufacture if you don`t want to start making your own:
Less drag = Less fuel | Aluminium wheel hubcaps | Eco Tuning --> Tuneko Ltd
Kit would include 4 round PC discs (tinted or clear) and 20 pcs of ziptie plugs and zipties. I can also heat them to little bit convex if you need them like that, so it can be done. Those ERA wheels are 10mm "convex".
Price varies little bit on wheelcover size but it will be between 150-200€ shipped to states. ( just Shipping will cost about 50$)
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
The Following 2 Users Say Thank You to Vekke For This Useful Post:
ericthemidget (07-07-2011), mcrews (07-10-2011)
Old 07-07-2011, 03:08 PM   #8 (permalink)
Those look good, and thinner/lighter than what people can make themselves
Old 07-07-2011, 04:41 PM   #9 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
You can make your own with jigsaw but the circle is very difficult to get "round" and looking nice. Material is 3mm thick tinted polykarbonate. Is it 1/8"?
Old 07-07-2011, 09:29 PM   #10 (permalink)
yeah about 1/8"
